redkiwi Posted August 26, 2006 Report Share Posted August 26, 2006 hi i want to know how to transfer tracks from a pc to mini disc and what software is needed to do it if anybody can help that would be much appreicated cheers redkiwi Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted August 26, 2006 Report Share Posted August 26, 2006 what minidisc unit are you using? The software needed is Sonicstage CP. It is downloadable from here or direct from Sony. This is assuming you have a USB capable unit. Quote Link to comment Share on other sites More sharing options...
redkiwi Posted August 28, 2006 Author Report Share Posted August 28, 2006 hi i want to know how to transfer tracks from a pc to mini disc and what software is needed to do it if anybody can help that would be much appreicated cheers redkiwi hihey ta for that, i'm doing this for a guy i play golf with he gave me the model number but it was wrong so i'll out today and post it then Quote Link to comment Share on other sites More sharing options...
redkiwi Posted September 6, 2006 Author Report Share Posted September 6, 2006 hi KrazyIvan the model mzne410 is it still Sonicstage CP ill need for my mate could also give me a run down on how to do it i would appreicate it cheers redkiwi Quote Link to comment Share on other sites More sharing options...
A440 Posted September 6, 2006 Report Share Posted September 6, 2006 (edited) You need to install SonicStage on a PC. (It won't work on a Mac.) Get the full 3.4 installer here:http://forums.minidisc.org/downloads/details.php?file=21or the 4.0 online installer from Sony via a link here:http://forums.minidisc.org/index.php?showtopic=9586Either one will do all you need for the MZ-NE410. If you're transferring mp3s that came from various sources, then I would recommend 3.4 because some people have found that 4.0 is very finicky about the kind of ID tags that are used. Install it. Open it. Connect the minidisc via USB. A window will open on the right listing all the tracks on the disc in the unit (if there are any). You need to import whatever folders of music you have into SonicStage and click the red arrow to transfer. It's pretty obvious once you're hooked up. Edited September 6, 2006 by A440 Quote Link to comment Share on other sites More sharing options...
