RH1 Vs M200
festus
Can anyone shine a light as to the exact difference between the the RH1 and the M200? According to the video clip that that's been doing the rounds it may be true peak detectors? or something about the mic bundled with it? (In which case why such different product codes?)
I already have a portable mic, ECM 719 for interviews, am I better combining this with the RH1 or what?
they are identical to each other, just the bundled mic....
check it out....
http://www.minidisco.com/Sony-MZ-M200?sc=7&category=10
Sector is right. If you go to his link and click on "OWNERS MANUAL" at the bottom (near the Add to Cart button), you'll see that it has both MZ-RH1 and MZ-M200 on it.
thanking you guys
