karmen12 Posted September 18, 2006 Report Share Posted September 18, 2006 Hi GuysI need help. I want convert my atrac3plus files back to mp3.How can I handle that???Please help me!Thank you all so muchLove Karmen Quote Link to comment Share on other sites More sharing options...
bobt Posted September 18, 2006 Report Share Posted September 18, 2006 Hi Karmen,What device do you have, and what version of Sonic Stage do you have? If any older than 3.4, get at least 3.4, or do to 4.o.There is a setting in 3.4 on creating a disc that lets you vreate an MP3 disc, that may be your easiest method, then transfer the MP3 disc to whatever folder you want.HTH, and welcome,Bob Quote Link to comment Share on other sites More sharing options...
A440 Posted September 18, 2006 Report Share Posted September 18, 2006 Are your atrac files on the computer or on a disc? On the computer, use HiMDRenderer.http://forums.minidisc.org/index.php?showtopic=12683The atrac files are .oma files. If they're on a disc, it will depend on what MD unit you have. Quote Link to comment Share on other sites More sharing options...
karmen12 Posted September 18, 2006 Author Report Share Posted September 18, 2006 Hi guys Thanks for yor help!!I have got an MD-MZ6oo(does it matter that it's blue )You are a great help!!! Quote Link to comment Share on other sites More sharing options...
A440 Posted September 18, 2006 Report Share Posted September 18, 2006 karmen12 said: I have got an MD-MZ6oo(does it matter that it's blue )Are you sure of that model? MZ-NH600, maybe? NF610? As long as you've got the files on the computer, it doesn't matter. Quote Link to comment Share on other sites More sharing options...
karmen12 Posted September 19, 2006 Author Report Share Posted September 19, 2006 A440 said: Are you sure of that model? MZ-NH600, maybe? NF610? As long as you've got the files on the computer, it doesn't matter.Yeah sorry you are right it is a MZ-NH600 ... I mixed it up Thx Quote Link to comment Share on other sites More sharing options...
A440 Posted September 19, 2006 Report Share Posted September 19, 2006 Since that is a Hi-MD unit, you should also be able to upload files from your discs (in PCM, Hi-SP or Hi-LP format) into SonicStage's My Library, and then convert them. Quote Link to comment Share on other sites More sharing options...
karmen12 Posted September 20, 2006 Author Report Share Posted September 20, 2006 Thank you so much guys you were a great help Quote Link to comment Share on other sites More sharing options...
