cmcorby Posted September 20, 2006 Report Share Posted September 20, 2006 Hi,Has anyone been able to enable ClearType in SS 4.0? I used the procedure posted here on SS 3.4 without any problem, but when I updated to 4.0, SonicStage crashed. I tried it again after reinstalling, but no luck.Thanks--these forums are always so helpful. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 21, 2006 Report Share Posted September 21, 2006 Hi,Has anyone been able to enable ClearType in SS 4.0? I used the procedure posted here on SS 3.4 without any problem, but when I updated to 4.0, SonicStage crashed. I tried it again after reinstalling, but no luck.Thanks--these forums are always so helpful.Welcome to MDCF! ClearType will work in SonicStage CP 4.0 as well. You will just need to reapply the edit as outlined once again; employ "UltraEdit-32" to save time as discussed within its discussion thread. Quote Link to comment Share on other sites More sharing options...
cmcorby Posted September 21, 2006 Author Report Share Posted September 21, 2006 Thanks for the reply! It must be something on my end. I used the "Ultra-Edit" method (big timesaver!!), so I know it's not a typo, and I checked the files to make sure that the edits are correct...so I'm stumped, especially since I used the same process on 3.4 without trouble.At least I know now that it should work, so I'll keep trying.Thanks again! Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 21, 2006 Report Share Posted September 21, 2006 Upon completion of your edit, do remember to delete "App.xml_" in "C:\Program Files\Sony\SonicStage\Data\XML" before running SonicStage CP 4.0. This step is crucial so that changes made to the XML files will be reflected accordingly. Good Luck. Quote Link to comment Share on other sites More sharing options...
cmcorby Posted September 21, 2006 Author Report Share Posted September 21, 2006 Success!! Well, it turned out it was a capitalization issue. In my edits, I had paired <font> with </Font>. Capitalizing the first tag made it work.Thanks for the help and for posting the original procedure--it makes a huge readability difference on my system. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 21, 2006 Report Share Posted September 21, 2006 I am pleased to hear of your success. Enjoy your stay with us. Quote Link to comment Share on other sites More sharing options...
