myktm250 Posted September 30, 2006 Report Share Posted September 30, 2006 (edited) hello alli have a sony mz nh900 hi-md deck and it gets used for multiple recording situationsthe last 2 shows i recorded have gaps in the recording,literally silent gaps in the wavesthers no rhyme or reason of them,they show up whereveri was using the lithium battery and the extra AA pack too when this has happenedits not a mic issue,i've looked into taht alreadyi use this deck for business purposes as well so i am very concerned about this problem,now when i use it for business purposes it is always plugged in,not running on batteriesi'm presently checking the last business recording to see if it has gaps as well,so maybe this is a battery issuethe only other thing is each show i recorded i used a "used" hi-md,i did erase it but i didn't format it each time,maybe this is an issueall help is greatly appreciatedplease resond here or email me direct myktm250@nrtco.neti need to get this problem figured out asap, cause i need the deck for business this weekendalso if anyone can reccomend any othe hi-md decks taht have a mic input taht would be great too,i need to buy another deck or 2thanxmike Edited September 30, 2006 by myktm250 Quote Link to comment Share on other sites More sharing options...
raintheory Posted September 30, 2006 Report Share Posted September 30, 2006 If you are reusing the same disc it is possible that the disc may be the culprit. You may want to test some other things, different recording modes, different discs, doing a test recording via line-in instead of mic-in... etc.I doubt it would be a battery issue. Usually most battery issues result in a completely lost recording because the battery ends up with not enough juice to write the TOC. Quote Link to comment Share on other sites More sharing options...
myktm250 Posted September 30, 2006 Author Report Share Posted September 30, 2006 hiyayeah i'm leaning towards the md myself tooevery time i do a business recording its on a new blank mdand i ahve recorded a few shows on the hi-md with fresh new blank hi-md discs and not ahd these gapping problemsand it didn't seem to make any sense leaning toward the powr supply,but honestly i was looking everywhere for answersmike Quote Link to comment Share on other sites More sharing options...
