Transfer file to Hi-MD
CA RO
Is there any software that supports transferring any files that are not added to library database?
With SS, I have to import the files I want to transfer before transfering them. Sometimes this is a little bit annoying!
Edited by CA RO
SonicStage and SimpleBurner are your only options. You have to use one of those two (though you need SonicStage installed for SimpleBurner to work) to get music onto your Hi-MD...
SimpleBurner is handy for when you have music on CD that you want to transfer, otherwise you would have to import the CD into SonicStage prior to transferring to Hi-MD.
The only exception would be recording in realtime via microphone or line/optical input.
Edited by raintheory
How can I sync a recording by opt? I tried but not succeeded :(
I read the manual of RH-910, it says that if using synchro-rec, normally it divides tracks after 3 secs without sound. I tried to stop my winamp for more than 3 secs, but it continues recording.
How can I deal with this?
Thank for your help
Edited by CA RO
