step-up voltage converters
WaywardTraveller
When I get back to Canada I'm in the market for at least one step-up 110V-220V voltage converter so I can use a Chinese 220V NH1 back home. I know you can find simple wall-plug converters pretty easy on Ebay, but I was wondering if anyone had any suggestions for some that can be found mor easily in stores like Staples/Best Lie/etc?
peace
WaywardTraveller
All you need is a normal 6 V adapter that will fit into the charging cradle, Radio Shack or Future shop should have them. If you really want to go with a step up device, try a travel shop they usually have stuff for going abroad.
Good luck,
Bob
