danjohadley Posted January 29, 2006 Report Share Posted January 29, 2006 I downloads the full install of Sonicsstage 3.3 and it install fine untill it gets to OpenMG source module where i get a pop-up saying Error 1606. Could no acces network location 0. adn i can retry or cancel here is a shot of it. If i retry it just says it again and if i cancel it carries on with the install and then after the restart sonicstage. wont start. If i do it offline i get to the same place but its brings up a window saying i have run out of disc sapce on volume 0 the window displays my hard disc space and floppy space. (i have tried inserting a floppy to no avail).My specs are1.46ghz Athlon512mb pc133 sdramAti Radeon 9250 256mb Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 29, 2006 Report Share Posted January 29, 2006 Danjohadley,Welcome to "AtracLife"I will suggest you to download SoncStage ver3.3 (From Atraclife download section again) Quote Link to comment Share on other sites More sharing options...
danjohadley Posted January 29, 2006 Author Report Share Posted January 29, 2006 Nope i just tried that and i got the same error message. Any ideas. i also tried the official sonly downloader and that didnt work either any ideas guys? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted January 29, 2006 Report Share Posted January 29, 2006 Resolution to the problem you experienced - "Error 1606: Could not access network location <common administrative tools>. All users\" error message when you install a program - can be found in Microsoft's software support site. Here's an excerpt from this link. For your reference, here's another page with description and resolutions to the "Error 1606." Good luck with the fix and do report back with your results.SYMPTOMSAfter you upgrade Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition to Microsoft Windows XP or Windows XP SP1, when you install a program on your Windows XP-based computer, you may receive an error message that is similar to the following: Error 1606. Could not access network location <Common Administrative Tools>.All users\. Additionally, nothing may occur when you try to open Administrative Tools in Control Panel.CAUSEThis behavior can occur if there is an incorrect setting in the following registry entry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\Common Administrative ToolsNote: This registry key exists only if you upgrade your computer from Windows 98 Second Edition to Windows XP or from Windows Millennium Edition to Windows XP.This behavior may also be caused by Norton AntiVirus 2003. For more information about this behavior and for steps that you can take to resolve the problem, visit the following Symantec Web site: http://service1.symantec.com/SUPPORT/sunse..._sch_nam&seg=ag (http://service1.symantec.com/SUPPORT/sunset-c2002kb.nsf/9b60813077fffd2385256ee60055ac57/8b5951c9ec10830085256edf00520f16?OpenDocument&src=bar_sch_nam&seg=ag)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. If the behavior still occurs after you take the steps to resolve the problem, remove Norton AntiVirus 2003 manually. If you cannot remove Norton AntiVirus by using the Add or Remove Programs tool, use the Rnav2003.exe utility. To remove Norton AntiVirus manually, click Add or Remove programs, click Norton Antivirus, and then clickRemove Programsin Control Panel. For information about how to download and use the Rnav2003.exe utility, visit the following Symantec Web site:http://service1.symantec.com/SUPPORT/nav.n...001092114452606 (http://service1.symantec.com/SUPPORT/nav.nsf/docid/2001092114452606)RESOLUTIONWarning This workaround may make your computer or your network more vulnerable to attack by malicious users or by malicious software such as viruses. We do not recommend this workaround but are providing this information so that you can implement this workaround at your own discretion. Use this workaround at your own risk.Note: An antivirus program is designed to help protect your computer from viruses. You must not download or open files from sources that you do not trust, visit Web sites that you do not trust, or open e-mail attachments when your antivirus program is disabled.For more information about computer viruses, click the following article number to view the article in the Microsoft Knowledge Base: 129972 (http://support.microsoft.com/kb/129972/) Computer viruses: description, prevention, and recovery Warning Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.To resolve this behavior, follow these steps.Click Start, and then click Run. In the Open box, type regedit, and then click OK. Locate and then click the following registry key:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders In the right pane of Registry Editor, double-click Common Administrative Tools. In the Value data box , type the following line, and then click OK: %ALLUSERSPROFILE%\Start Menu\Programs\Administrative Tools On the File menu, click Exit to quit Registry Editor. Restart the computer. Quote Link to comment Share on other sites More sharing options...
danjohadley Posted January 29, 2006 Author Report Share Posted January 29, 2006 Well i followed all the instryctions and when i got the the user shell account i found that i have no common administerive tools ????????. I dont know if i should But i dont know if i should create it or how? Quote Link to comment Share on other sites More sharing options...
