Problem with my Sony MZ-N707
choochootrain
Hey,
I have a Sony MZ-N707 md, and I use OpenMG to transfer my songs to it. Back then, I never had any problems transferring or playing songs with my md, but recently its been kind of whacky. When I transfer songs to my md, some of the songs play, but then some of them do not. The songs that I previously had on the md from a while back still play perfectly fine, but some of these new transferred songs do not play and when they do play there seems to be a lot of static and the song becomes choppy. Also, I've tried transferring the songs a couple of times and it seems random as to what songs are playable. For example, I transferred Jingle Bells to my md and it plays, but after I delete it from the md and transfer it again the next time, it won't play. Is this a problem with my md player or my md's? How do I fix this problem?
More than likely your record head is getting flaky. Do not use your unit any more, it will start randomly erasing discs. See if an electronics shop can fix the wiring, or get a first generation Hi-MD or an RH1.
But above all, do not put anything recorded back into your 707 till it is fixed.
Bob
Hey,
I tried recording mic/line-in recordings like you told me to, but when I play it back it doesn't seem to play. I don't hear anything. The timer says it plays for two seconds and then stops and loads for a while and then plays two seconds and then loads again, doing this constantly. So does that mean my record head is flaky like bobt says, or what? If so, is it worth it to get it fixed or should I just buy a new one altogether?
Hey,
Take it it a repair facility you trust and see if it can be done for under $50.00. If it is more, you can get a very decent 1st generation, I would go NH 700 or 800 if budget is an issue, NH 1 if it isn't. If you are willing to go for the NH1, you mught as well go all the way and get an RH1.
Good luck,
Bob
