Uploading - what cable to use and where to connect
moreAAs
I am totally new to uploading - have been recording so have lots of material to upload - but new to it. So, I basically need to know where to start.
I read the "essential uploading guide" here, but it says to use a USB cable. I went to radio shack and they were like, "Huh?" when I mentioned a USB cable with an .8" input on the other end.
Will a regular audio cable work? If not, where would I find such a USB cable?
I've downloaded SonicStage 4.0, but any other tips for starting an upload would be of help.
Thanks!
The small end of the USB cable is a standard "5-Pin Mini B" plug. Common for use on digital cameras and other devices.
IPB Image
Plug the small end into your Hi-MD and the standard USB into your PC. The device should show up in SonicStage and allow you to transfer with ease.
Edited by raintheory
that did the trick :ok:
the battery pack was blocking the USB port, so I couldn't even see that there was a place for the small end of the cable. Camera cable worked fine. Sonicstage took it from there. Very easy after that first step. Thanks!!!!!
Edited by moreAAs
Thanks!
what have you been recording? what mics what settings?
