bill34999 Posted December 6, 2006 Report Share Posted December 6, 2006 Hi,I am interested in doing quite a number of interviews on a digital format that can easily be upload onto a computer.I am interested in the minidisc because a) its quality and it leaves a copy of the recording on the MD after the upload.My questions are: 1. Is there a good/recommended model for interviews? 2. What is the best format for recording and uploading? 3. Whereis the best place to buy a minidisc player. I am in Europe and understand there are some limitations on the output signal. Also, the dollar is cheap!ThanksBill Quote Link to comment Share on other sites More sharing options...
A440 Posted December 6, 2006 Report Share Posted December 6, 2006 Cheapest recorder with a mic jack: MZ-NH700. Look at http://www.minidiscaccess.com or Ebay. It's a great little workhorse, perfectly fine for interviewing or music. All Hi-MD recorders basically record with the same quality and upload the recordings to PC. Fanciest recorder, with a lot of features you don't need: MZ-RH1. Also try US outlets. You probably know that you'll also need a microphone: MD recorders don't have them built in. On the MZ-NH700 (and all other Hi-MD recorders except the MZ-RH1), there are three uploadable formats: PCM, which is CD-quality and probably far more than you need for an interview; Hi-SP, just under 8 hours per 1GB disc or 140 minutes per 80-minute disc, or Hi-LP, which will give you four times as much recording time per disc. Hi-LP may well be good enough for interviews; Hi-SP definitely will be. Choose your format, plug in the mic and push Record (which will default to Automatic Gain Control, good for interviews). Enjoy your interviewing. Quote Link to comment Share on other sites More sharing options...
