trying to find openMG secure module
sunshinin
Hi,
I accidentally erased a file belonging to Sonic Stage software-
and i can't open sonic stage anymore; a message appears saying
it can't find OpenMG Module; is it possible to download just the
OpenMG module? or do i have to download the whole of sonic stage again?
And if so, will all the music i have in my current sonic stage
library be lost? i live in france, so if anyone knows of the link to
download or a solution would be great! thanks!
See if it's possible to run the Backup Tool, which should be under Start/Programs/SonicStage but runs separately from SonicStage. With luck you will be able to run the Backup Tool so that you will have a backup of My Library.
Usually installing a later version of SonicStage doesn't mess up your library, but yes, it can. Unless you can back it up, you are just going to have to hope for the best.
OpenMG is the core of SonicStage, and even if you know the exact version you were running it is not going to be easy to find separately.
There are SonicStage downloads and links under Downloads, on the upper left of this page. There is also a link to a full installer for 3.4 here:
http://www.savefile.com/files/194995
Edited by A440
@ sunshinin: What version of SonicStage you have installed? I may be able to provide you with certain version of OpenMG Secure Module.
In any case, if you are able to run SonicStage Backup Tool as suggested by A440, please reinstall SonicStage (preferably the latest version: SonicStage CP 4.2) after backing up your ATRAC library. Should you require assistance with reinstallation, please review our SonicStage Software FAQ for further details.
