Where to get MZ-RH910
RJSkypala
AudioCubes, but you'll find that their RH910's price is close to the RH1's. You can also try looking for the MZ-M10 (http://www.minidisc.org/part_Sony_MZ-M10+RH910.html). Those are still around, but also at a price near the RH1's. Good luck!
Maybe I'm a little slow, but I never saw the point of the 2d-generation units like the RH910. The change from the NH generation was that the RH could play mp3 files directly--but until the RH1, mp3 playback sounded dull because of a high-frequency cutoff. And in the meantime, the ability to record in realtime to old MD formats was removed.
To me, the best quality/price ratio is still the NH700. It's a little fatter on one end, and a lot more convenient, because it takes an AA battery rather than a gumstick. It has a mic jack (along with line-in) and records as well as any other Hi-MD. And it stands up to a lot of use. You can find it here:
http://www.minidiscaccess.com/item.html?PRID=1553220
or even cheaper on eBay.
