Can Hi-MD Music Transfer for Mac 2.0 handle ID3 tags?
fanimej
Just came up with a new question; can the RH1 handle ID3-tags?
Let's say i have a mp3-file in iTunes and i wanna transfer it to the RH1, do i then have to type in the songtitle and artist (and album) in the "hi-md music transfer for mac"-program or is it enough to just drag the file from iTunes to the RH1, and that the RH1 then can display songtitle, artist and album in the remote?
Checking...
EDIT (Results):
ID3 tags transfer fine from Mac to the RH1 (displayed on remote).
However, you cannot drag directly from iTunes to the music transfer window. My workaround was to drag from iTunes to the desktop (creating a copy) and then drag the mp3 file from desktop into music transfer window. Apparently you have to drag an actual mp3 file into the window. Odd behaviour (since dragging from iTunes to desktop creates a copy of the mp3 anyway) that will hopefully be fixed in a newer version of the software, if one is released.
Edited by raintheory
