"NO FILE" when i place my ATRAC CD in
Hou_JaI
Hello all, I am having some problem with my cd player (d-ne10 model). When i insert an atrac cd in and press play, it load for a while and then it says "NO FILE". After that it shut off itself... I have tried all my ATRAC CD and getting the same problem ... but when i insert an audio cd .. it works :o ... Please aid me
THanks!
3 answers to this question
  Stuge said:
have you used the Blank cd to make atrac cd ?
Also don`t put any other files other then Atrac Files via SonicStage
Which version of Sonic Stage you are using ????
Yes its a blank cd, I did not put any files in the cd at all, its brand new . I am using SS 3.4 the latest version.
My previous ATRAC CD also can't be loaded by the player ...
All i know is after I played a newly made ATRAC CD this afternoon which kept failing (the player keep skipping the tracks but i dont know why ... :sad: ) ... then when i try to switch to another ATRAC CD I get the "NO FILE" error ...
Kindly assist B)
