RCA, phono, digital interconnects - max length?
batfastad
Hi guys
I was just wondering what the maximum length of RCA / phono hifi interconnects is?
All mine are Cambridge Audio Pacific 1m long, but I was wondering if there are any longer available?
Basically I want to hook my mixer (Pioneer DJM600) up to my surround sound receiver that's the other side of the room. Probably about 15-20m away.
I'm assuming it would be better to do this digitally though, as I guess these digital standards can have a longer max cable length than conventional analogue interconnects.
What's the maximum length of digital optical / coax cable you can get?
What are the max lengths I could use without having quality loss?
Also are there any adaptors that can convert an analogue RCA connection into a digital optical / coax or something?
I know I could get a full-on DAC, but I was wondering if there's anything smaller / cheaper?
Out of interest, are there any other digital cable standards that might be useful for this and give a longer transmission distance?
Using ethernet cables or other fibre optic standards for example? :D
Anyone know of any sites I can look at some longer hifi cables?
I'm in the UK.
Any comments / suggestions on how best to do this? :D :D
Thanks
Ben
