jonmarcus Posted January 18, 2007 Report Share Posted January 18, 2007 I've spent quite a lot of time going through this section but can't find the answer so hopefully someone can help.I 've tried deleting certain tracks in My Library and also checked the box to delete them from my hard drive (to save disk space). The message "If you delete the tracks from the computer, you cannot restore them again. Tracks transferred to device/media cannot be transferred to the computer. Are you sure you want to delete the tracks?"What does this mean? I'm sure I have deleted previous tracks from both My Library and the hard disk without this message coming up (but can't be sure).For example - Does this mean that if I delete a track from the computer that I will not be able to import that track in the future from the same CD?Is this a DRM issue? I thought SS3.4 got rid of DRM problems.Also, it appears that the file in the All Users/Sonicstage/Packages directory is roughly the same size as the file in My Library, and so presumably uses up the same amount of disk space again. This is something that I do not want and in the interests of saving disk space I would be really grateful if someone could advise me what I can do, if anything.Thanks. Quote Link to comment Share on other sites More sharing options...
