getting a set to format
xai313
Ok. I was going to buy one of those real time cd burners I've been hearing about but a friend of mine talked me into gettin an MD package fro recording my dj sets This way I could re use MDs and only burn CDs out of the final demos. (I'm not sure of the model number) but I use an MD deck hooked up to my mixer to get the recording onto a MD. Now I need to get the mixes from MD onto CD. so I got this Net MD MZ-NE410 and SonicStage but eerytime I try and transfer the trax onto my harddrive (I checked the stats and this computer should make the transfers no problem). I keep getting this error message "Unable to transfer the following tracks to My Library because they are recorded
by Net MD or another computer."
does anyone know how or what to do.
again I am kind of new at this but hopefully someone can help me trouble shoot this problem.
xai313
NetMD units like the MZ-NE410 don't upload. The USB connection is one-way, from PC out to MD in, for the MD to be used as a player like an iPod.
There's no way around it--it's in the hardware.
The only unit that will upload the recordings from your MD deck is the MZ-RH1 because they are in the original MD format. No other unit will upload them, including previous Hi-MD units.
You might as well record with the RH1, too--you can get CD-quality PCM sound (90 minutes per 1GB disc), better than the compressed formats on your deck. At $330, the MZ-RH1 is about half the price of a realtime CD recorder, and a lot smaller.
Other Hi-MD units (MZ-NH**, MZ-RH**) will also record in PCM and upload their own recordings. The cheapest one around is the MZ-NH700, about $180 from http://www.minidiscaccess.com . Its other advantage is that it runs on a regular AA battery.
But only the MZ-RH1 will upload your deck recordings. Otherwise, the only way to copy them is to record them in real time out of the headphone jack.
Edited by A440
Hey thanks, I guess I'll have to look into another unit. I tell you man this is not a cheap hobby
but again thanks for the advice. I'll look around and see what I can do.
xai313
