masao Posted January 24, 2007 Report Share Posted January 24, 2007 1. I have a NetMD here (Sharp IM-DR420H). Can I use it with Simple Burner?2. Are MD decks really the only way to upload digitally from MD to PC (using a NetMD portable device)? Quote Link to comment Share on other sites More sharing options...
A440 Posted January 24, 2007 Report Share Posted January 24, 2007 1. I have a NetMD here (Sharp IM-DR420H). Can I use it with Simple Burner?2. Are MD decks really the only way to upload digitally from MD to PC (using a NetMD portable device)?I don't know about SimpleBurner but my guess is that if SonicStage has your drivers, you can use it. Why not just get it from Downloads and try it?Decks won't upload. You need the MZ-RH1, which uploads all formats (SP, LP2, LP4, Hi-LP, Hi-SP, PCM) EXCEPT songs you downloaded from CD to computer through SonicStage onto NetMD units. Quote Link to comment Share on other sites More sharing options...
masao Posted January 24, 2007 Author Report Share Posted January 24, 2007 (edited) Decks won't upload.Well, with "upload" I actually meant to transfer the songs I've recorded (say a live concert) digitally without loss to my computer.I assumed I can do that with MD decks by using the "Digital in", can I? My Sharp has an "Optical in", is that compatible to "SPDIF Out" on an audio card? Edited January 24, 2007 by masao Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted January 24, 2007 Report Share Posted January 24, 2007 You'd actually need to use the digital out on a deck attached to a PC to 'transfer' it digitally. Not all decks have digital out, so check the specs before hand, eg, Sony MDS-JB980 and 780 have optical digital out.The easiest way to upload though would be using the lastest (last?) Sony MD portable, the MZ-RH1, which uses a USB cable to upload recordings directly and faster than realtime. Quote Link to comment Share on other sites More sharing options...
1kyle Posted January 26, 2007 Report Share Posted January 26, 2007 You'd actually need to use the digital out on a deck attached to a PC to 'transfer' it digitally. Not all decks have digital out, so check the specs before hand, eg, Sony MDS-JB980 and 780 have optical digital out.The easiest way to upload though would be using the lastest (last?) Sony MD portable, the MZ-RH1, which uses a USB cable to upload recordings directly and faster than realtime.Optical uploading needs to be done in Real Time (slow) -- and you'll probably have to re label your music etc.As the poster says it's easier (and quicker) to do it using an RH1.Cheers-K Quote Link to comment Share on other sites More sharing options...
ramb0 Posted January 29, 2007 Report Share Posted January 29, 2007 (edited) masao:First of all, I assume you are using WIN XP - my experience with MD software namely ends here. 1. I own the same MD. You can use it with Simple Burner and even with Sonic Stage, BUT BEWARE: BeatJam and SonicStage are not compatible pieces of software! An attemp to install BeatJam, deinstall it and install Sonic Stage messed up my machine completely every time I tried that. However, there are certain modules/drivers/some pieces of software in short that Simple Burner needs in order to function but weren't included in the installation files I have worked with.I made a new system-installation yesterday and since the MD software was causing me terrible headaches in the past I came to check whether any new sofwtare is available. I posted an extensive post about how to work around this problem a couple of hours ago but now I finally seem to have found an acceptable solution without having to spend two afternoons in front of the monitor and swearing Sharp. The link to the new 4.2 Sonic Stage on the forum site worked for me fine. I am using XP SP2, installed just the MD drivers first, then plugged-in the MD so that the installation was completed and then installed the whole Sonic Stage pack (couldn't exclude the Sony drivers that were causing me so much trouble in the past, though), including the Simple Burner, and - miracle - it works!From my previous experience with SS 2 and 3 I can tell that it is possible to have working installations of either SB and BJ or SB and SS at the same time. I have never managed to run SS and BJ at the same time, however. As mentioned before, I think that at least what Simple Burner needs to function properly is the OpenMG component.If you will stick to BeatJam and it won't work properly, I'd also like to make you aware of a SP1 issue - just take a look around the forum, there's a patch available. 2. I can't argue about this since I haven't tried it, but I seriously doubt that you can simply put a MD recorded with your Sharp into a RH1 Sony and transfer the contents via USB. Sony engineers are not that dumb, I guess. You can, however, use the optical line-out of your MD to transfer the contents to a computer in real time. Stand-alone components with recording capabilites that are equipped with an optical line-in have in many cases copy protection built-in so you will most likely be limited to a PC as the exporting target.Hope, you'll figure everything out soon! Edited January 29, 2007 by ramb0 Quote Link to comment Share on other sites More sharing options...
