jd76 Posted February 6, 2006 Report Share Posted February 6, 2006 I would like to upgrade to sonic stage 3.4 but when I attempt to do so it tells me that older versions will be uninstalled. I don't have a problem with this but I have 1600 tracks in my old SS setup. Will these tracks/albums be preservered..they will not be deleted will they ??? Thanks JD76. Quote Link to comment Share on other sites More sharing options...
delvatron Posted February 6, 2006 Report Share Posted February 6, 2006 When I upgraded mine last week there were no problems. If you are worried you can always backup the databse first using the Sonicstage Backup Tool. Then once installed if you have lost the database just restore the backup. It only backs up the music files and database, not the version of Sonicstage.Hope this helps Quote Link to comment Share on other sites More sharing options...
jd76 Posted February 6, 2006 Author Report Share Posted February 6, 2006 thanks delvatron that's a good idea. i'll give this a try. by the way how do you find version 3.4? Quote Link to comment Share on other sites More sharing options...
jd76 Posted February 6, 2006 Author Report Share Posted February 6, 2006 thank delvatron..all updated successfully...JD76 Quote Link to comment Share on other sites More sharing options...
delvatron Posted February 7, 2006 Report Share Posted February 7, 2006 I thought the software was a tad bit quicker than before and I can now download album art from gracenote rather than get them from amazon. Overall an improvement. Now if only they could include some means of downloading podcasts directly.... Quote Link to comment Share on other sites More sharing options...
