glopezsant@hotmail.com Posted February 14, 2007 Report Share Posted February 14, 2007 Hi. I am currently transferring all my vynil lp's, 45 rpm's and 12" into mini disc records. I have a Sony Mini Disc Deck MXD-D400 in which i do the "dirty job" of transferring my collection from vynil to MD usually in the LP2 Stereo Mode. I also own a 60 GB IPOD in which i am also transferring my CD collection too (as you can imagine I am a huge Music fan). Some time ago I purchased a portable Sony MD Walkman (Hi-MD Audio) Model MZ-NH1 with PC compatibility and USB Port with the intention to transfer my current vynil collection recorded into Mini Discs (about 80 pieces so far) to I tunes and eventually my IPOD. Now my nightmare... After trying several times I finally got a way to do the work: installing the Sonic Stage V. 4.2. I installed the software (My computer is a Sony VAIO, as you can imagine I am a Sony product fan also) and finally got a way to see the tracks recorded on my Mini Discs into the installed software. My problems is that when I try to transfer the tracks from the Net MD screen to My Library into the PC it gives me the following error: "Unable to transfer the following tracks to My Library because they are recorded by Net MD or another computer". I looked into the Help Index of the Software and found the following explanation: "Tracks recorded on a conventional MD device can be imported only with an MD-importing compatible device". I don't get it. Shall i quit on my intention? What seems to be the problem? Is there a way I can solve this situation to finally get my vynil records into the PC? Please, anybody knows what I can do to solve this problem? I am frankly desperate to the point of throwing away the portable MD (Just kidding!!) Quote Link to comment Share on other sites More sharing options...
raintheory Posted February 14, 2007 Report Share Posted February 14, 2007 (edited) The only recorder available at this time that will upload those legacy recordings is the MZ-RH1. Do a quick search in the forums for more info.In short, you would either need the RH1 (fastest method, digital quality), a deck with optical out>soundcard with optical in (slower method, digital quality), or analogue line from headphone jack>line-in on soundcard (slower method, analogue recording).EDIT: Here is a good starting point for info: http://forums.minidisc.org/index.php?showtopic=7070 (includes a good explanation of the analogue method). Edited February 14, 2007 by raintheory Quote Link to comment Share on other sites More sharing options...
glopezsant@hotmail.com Posted February 14, 2007 Author Report Share Posted February 14, 2007 The only recorder available at this time that will upload those legacy recordings is the MZ-RH1. Do a quick search in the forums for more info.In short, you would either need the RH1 (fastest method, digital quality), a deck with optical out>soundcard with optical in (slower method, digital quality), analogue line from headphone jack>line-in on soundcard (slower method, analogue recording).Thanks man. Im not well familiar with all your recommendations about my computer but I looked into EBAY and I think Im gonna buy the model you recommended. It is that way, or forever stay with my vynil collection into the Mini Discs. I wish I would have known this fact before I purchased the MZ-NH1. In fact I currently own 3 MD models: The Sony MZ-R37 and the MZ-E3 (Player Only) and the MZ-NH1. I didn't know the last one wasnt fit for uploading ( I thought that USB port connection was enough to upload my well protected records). Thanks a lot for your help!! Quote Link to comment Share on other sites More sharing options...
A440 Posted February 14, 2007 Report Share Posted February 14, 2007 I don't know if you are still in the process of recording your vinyl to minidiscs, but if you are, you could also just record them directly into your computer--headphone out of your amplifier to line-in (preferably) or mic-in (if there's no line-in) to your computer, in realtime with Audacity. http://audacity.sourceforge.net/download/windowsLP2 does not give you very good sound quality. You would be much better off recording into the computer directly. Quote Link to comment Share on other sites More sharing options...
raintheory Posted February 14, 2007 Report Share Posted February 14, 2007 For reference, you can upload recordings that you make using the NH1 in Hi-MD mode, just not the older recordings. Quote Link to comment Share on other sites More sharing options...
