1kyle Posted February 16, 2007 Report Share Posted February 16, 2007 (edited) I've had no probs running SS 4.3 on a 32 bit Vista premium edition. I've also run this successfully on a Vista VM machine (again 32 bit) running as a GUEST OS under VMWARE running SUSE 10.2 (32 bit again) as the HOST OS.I haven't tried the 64 bit version s yet but the 32 bit works fine.I'm a bit disappointed about the end of Simple Burner as with Simple Burner you can burn to MD directly 4.3 without loading to the library first which is quite a useful feature when ripping CD's. With SS you have to import into the library first (an extra step).I wish SS 4.3 would have had the Transfer / burn to MD (or other walkman device) directly without having to import into a library first.However if you DO have to import from a music library It seems to be "snazzier" or "zippier" than previous versions of SS --even with the "bloatware" overhead of Vista.Haven't tried this on XP yet but I'll have a go running on a Windows XP VM as I can test this quite easily later.BTW MD simple burner DOES actually work on Vista 32 bit currently - download the drivers as well for Net MD etc.Cheers-K Edited February 16, 2007 by 1kyle Quote Link to comment Share on other sites More sharing options...
WaywardTraveller Posted February 18, 2007 Report Share Posted February 18, 2007 Haven't tried this on XP yet but I'll have a go running on a Windows XP VM as I can test this quite easily later.BTW MD simple burner DOES actually work on Vista 32 bit currently - download the drivers as well for Net MD etc.I thought SS4.3 was basically SS4.2 for Vista and not for XP...?I know this is a bit off-topic, but I know very little right now about Vista. I hear it's NOT downwards-compatible with any previous version of Windows - is this true? Does this mean one couldn't run SS4.2 for whatever reason?peaceWaywardtraveller Quote Link to comment Share on other sites More sharing options...
