RM-MC60 + MZ-RH1 = perfect line-out
Avrin
Finally got an RH1 today! Well, the unit is really, really, really good sounding, and almost perfect. The only not well thought-of thing in it is the location of the input/output jacks - on the left side and too low. When I plug a standard cable to output the sound to my HiFi system, its minijack lifts the unit quite a bit. On the other hand, the minijack on the supplied remote is quite small, but just as you plug the remote (the RM-MC38EL in my case), the line-out mode is gone from the menu, and the unit switches itself to the Headphone mode.
But guess what? I tried the "useless" LCD-less RM-MC60, which came with my old RH10. Turns out that it does not affect the menu, and the mode, as long as you don't touch anything on it (the HOLD switch serves perfectly to prevent accidental touches). Now I have a nice small jack, a cord going straight to the back side, AND the line-out!
And the RM-MC60 does not add any noise or distortions, since it does not have an LCD circuit, and its button cicruitry in nothing but a bunch of resistors.
Edited by Avrin
