saul Posted March 2, 2007 Report Share Posted March 2, 2007 Hi,I have a sony mzn510 types,and a sony ecm 717 mic.the mic has a long cord.when i plug the mic into the lineout and do recording,the playback volume is very low.even with the recording volume on max and the unit volume all the way down,i still have this problem.Any one out there have any ideas why this might be happening? also the player and mic both have new batteries.thanks alot for the help Quote Link to comment Share on other sites More sharing options...
A440 Posted March 2, 2007 Report Share Posted March 2, 2007 That recorder is not made for microphone recording. It has a (white) line-in jack, which expects an amplified signal, like the output of a CD player. It does not have a (red) mic-in jack, which amplifies the much lower signal from a microphone with a built-in preamplifier. You can buy a separate preamplifier, but it would probably be cheaper to simply get another MD recorder with a microphone jack. None of the units beginning with a 5 (like MZ-N505, etc.) has a mic jack .Look at the models here (there's a column called Connectors with each unit listed) to make sure any unit you are considering has a mic jack. http://www.minidisc.org/equipment_browser.html Quote Link to comment Share on other sites More sharing options...
