MZ-RH1 Mac
solomon707
Welcome to the forums. :)
Download "Hi-MD Music Transfer for Macintosh v2.0" from the downloads section here in the forums. You can then drag .mp3 or .wav files into the program's window to transfer them to the unit.
http://forums.minidisc.org/downloads/details.php?file=95 (the login is the same as the one you use here)
If you installed the version that came with your unit, uninstall it and install this newer one. I'm unsure if the older version supports this feature or if it only allows uploads and not downloads.
Thanks for the quick reply. Sony's instructions are useless for Macs, but I found the updated app on Sony's site right after I posted. Sound quality is awesome. As a fairly accomplished gadgeteer and former iPod user, the MZ-RH1 is undoubtedly my best recent acquisition. Can't wait to record some concerts!
There is a wealth of information here in the forums regarding using Minidisc for live concerts. If you run into any problems or have any questions/suggestions/etc, the community here is great and we are always happy to help out.
Since it can be tricky business, here is a link to the Live Recording section of the forum: http://forums.minidisc.org/index.php?showforum=18
Even if you are experienced at live recording, there are some tricks and tips in there that may be helpful.
