Old MDX-C5300 (JPEC) - Format Difference?
RedHerring
I purchased a Skyline from Japan, came with a Sony MiniDisc [MDX-C5300].
I've been trying to record MDs and play them in the car, but it will either return ERROR or BLANK.
I've tried recording in LP2 (which I assume is too new), and Compatibility Mode (SP) in Sonic Stage with no luck.
Is there a format difference between NA and JP? Would I need different disks or different software?
Any help would be appreciated -- of course there is also the possibility the head unit is just FUBAR.
EDIT:
I did a little more searching on the forum and found that there is no difference in format or region.
I've initialized the disk and try recording again in SP mode (just in case).
I understand these can be a bit particular.
Edited by RedHerring
Does it resemble this model? http://www.minidisc.org/part_Sony_MDX-C5400X.html
I didn't see that model number in the Browser. The one I linked to does not support MDLP (just prior to its introduction) no your LP2/LP4 discs would show am being blank despite the fact they can be played.
There is no true SP mode in Sonic Stage meaning the deck cannot play any of your current discs - do you have a legacy SP mode on any recorder? The fact the deck spits out a disc may mean there is something broken in the loading mechanism, as well. Good luck.
