Fedelio Posted February 13, 2006 Report Share Posted February 13, 2006 Hi,Some days ago I bought Sony NW-A608 player. Nice thing.But now I have 2 issues.1. Can't transfer music files using SonicStage 3.3. I read the forum - installed-reinstalled SonicStage several times, installed it on both XP SP1 & SP2.When I try to transfer any file (mp3, oma), it begins and then shows the message "Error report: Unable to transfer the track or tracks: [tracks names]". After that it says that there is enought free space on my player.When I try to erase the player content, it erases the content, but then displays the message "Initizalization of the media failed (Error code: 0000662e)".ConnectPlayer works "fine", but it's a very slow application and I don't like it.Please, help! I didn't sleep all the night and I don't know what to do now... ((2. Yesterday I've noticed that there is background noise in player's head-phones. I didn't notice it before.It looks like you're listening a tape recorder with an old loud speaker. When I set the volume to 0 I still hear the background noise. When I try to use another head-phones (standard big head-phones for my PC) it seems that the noise is gone. Can the problem be in new Sony's head-phones? Do I need to buy another ones?..Thank you very much.Fedelio Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 FedelioWelcome to AtracLifeFirst of all install SonicStage ver3.4 .Are you formatting you player from the player`s advanced menu ?? Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 First of all install SonicStage ver3.4 .Hi Stuge,Where can I download full installer of v3.4 (not online)? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 Hi Stuge,Where can I download full installer of v3.4 (not online)?Full installer of SonicStage ver3.4 is still not available but will be available shortly. Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 Unfortunately, I can't install it online... Do you know why SonicStage 3.3 doesn't work with NW-A608, but detects it correctly?Is it a "feature" or what? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 Unfortunately, I can't install it online... Are you using proxy ip address or Firewall ??Do you know why SonicStage 3.3 doesn't work with NW-A608, but detects it correctly?Is it a "feature" or what?Did you do something with your computer Windows ???Were you able to use SonicStage ver3.3 before ?? Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 Are you using proxy ip address or Firewall ??Did you do something with your computer Windows ???Were you able to use SonicStage ver3.3 before ??Stuge, I can't install it online not because I have firewall, etc.But I'll try to solve this problem.(I have the full installer for SS 3.3. Do you know during what period SS3.4 will be available (full)?) Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 Are you formatting you player from the player`s advanced menu ??Once more question about formatting.Did you ask about formatting using ConnectPlayer or SonicStage?I formatted the player in ConnectPlayer, but there is no option to format it from SonicStage... or I missed something? Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 Stage, I don't know that I'm so stupid Of course you asked about Advanced menu in the player. But! I couldn't see such an option later! I tried all player's features, but I couldn't find (there were no these options!) "Advanced", "Cue/Rev", "USB", etc... Why? Why these options are available now? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 Press the menu button for a second then scroll down using jog shuttle then enter advance menu then .you will see format option in the player .Please do not format your player using windows explorer . Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 (edited) Stuge, I've formatted the player already. I don't know how I couldn't enter the menu before... It seems that it all work fine now. Thank you very much.Do you know where can I download a full manual for NW-A608?---What about the background noise in the player? Are standard Sony's head-phones good enough? Or is it the player's issue?---And the last question: is it true that a608 support USB 2.0? I don't think that my player is connected using USB 2.0, because transfer speed is very slow. I tried to copy files using Explorer and the speed was about 500-800 Kb/s. It's very slow. (the player is connected to USB root hub (without any additional hubs, directly to the PC) and USB is configured normally) Edited February 13, 2006 by Fedelio Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 You can download Full A600 manual from the download section of the forumNW-A600 Full Operating ManualSony`s earphones(MDR-E931) shipped with the player are good but they are very uncomfortable for some .Are you taking about the Hiss?Hiss also depends upon the quality of Audio cd .e can reduce the playback noise during ripping through SonicStage .In Tools=>Options =>Cd Importing =>check on cd writing settings.Yes ,its true that A608 does support USB 2.But computer your should be USB 2 as well to support it . Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 You can download Full A600 manual from the download section of the forumThanks.Sony`s earphones(MDR-E931) shipped with the player are good but they are very uncomfortable for some .You're right, they are not comfortable enough.Are you taking about the Hiss?Hiss also depends upon the quality of Audio cd .e can reduce the playback noise during ripping through SonicStage In Tools=>Options =>Cd Importing =>check on cd writing settings.Yes, its true that A608 does support USB 2.But computer your should be USB 2 as well to support it .Yes, it looks like a microphone hiss. As I said above, I hear it even when I set the volume to 0. I tried many different songs with good/bad quality - there is no difference. Besides, I don't hear the hiss on my PC.About USB. I'm working with PC very long time and know much about hardware/software, but as I said above my USB supports 2.0 (I use USB flash 2.0 drive). So, the problem isn't in USB adapter. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 Yes, it looks like a microphone hiss. As I said above, I hear it even when I set the volume to 0. I tried many different songs with good/bad quality - there is no difference. Besides, I don't hear the hiss on my PC.Iknow that USB 2 devices are very fast but since i haven`t used A608 so i can`t comment on that .Many people in the forum have repoted hiss from their players but i haven`t listen to hiss except in one of two mp3 that i have .But you can look here What hiss? Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 13, 2006 Author Report Share Posted February 13, 2006 (edited) Iknow that USB 2 devices are very fast but since i haven`t used A608 so i can`t comment on that .Many people in the forum have repoted hiss from their players but i haven`t listen to hiss except in one of two mp3 that i have .But you can look here What hiss? Hm-m... It's interesting. Some people have the same problem. It's not good.The player is amazing, but the hissss...... it's killing the admiration.Well, I think I'll try also the player with another headphones. Could you advice good low-end/high-end headphones, please (unfortunately, I don't know audio accessories very well)? Edited February 13, 2006 by Fedelio Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 13, 2006 Report Share Posted February 13, 2006 You can look for MDR-EX71/51.or first look herehttp://www.sonystyle.com/is-bin/INTERSHOP....ones&Dept=audio Quote Link to comment Share on other sites More sharing options...
Fedelio Posted February 14, 2006 Author Report Share Posted February 14, 2006 (edited) Thanks, Stuge. I appreciate your help. Edited February 15, 2006 by Fedelio Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted February 15, 2006 Report Share Posted February 15, 2006 You can also look here http://www.atraclife.com/forums/index.php?...st=0entry8868 Quote Link to comment Share on other sites More sharing options...
