SonicStage 4.2 renaming transferred tracks
flyingpylon
I just upgraded to SonicStage 4.2 (after failing to get 4.3 to recognize my RH10... I'm on XP anyway). I see that SonicStage now renames transferred tracks that I've recorded and also puts them in a separate folder named with the date and time they were transferred. Whatever the older version was that I was using didn't do this, and I'd like to know if there is a way to turn this off.
For example, it creates a folder called Hi-MD 5-15-07 21-00 (or something like that, I'm guessing). Then, it adds a 3-digit counter to the front of each filename: 001-myfilename.oma.
This actually creates a bunch of extra work for me that I didn't use to have to do.
Thanks for any advice.
