CarolinePiercy Posted July 4, 2007 Report Share Posted July 4, 2007 Hello Everyone,Sorry if these questions are answered elsewhere...I am recording interviews with two people at once. I have MZ-NH700 and two SONY mono electret microphones ECM-C10.First question, (for my purposes - analysing speech sounds) I need the sound wave to not be compressed at all or if it is as little as possible. Am I right that I need to record in PCM mode? I only have MDs to record onto not HI-MDs.Second question, after I have recorded the speakers I transrcibe the recordings. I sometimes have trouble with this as sometimes the people sound very similar! I was wondering if there was anyway of recording in two channels to make the task a bit easier?Thanks for your help...Best wishes,Caroline Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted July 4, 2007 Report Share Posted July 4, 2007 You can record in PCM on 'normal' MDs with your NH700. Just make sure you choose Hi-MD mode from the Option - Disc Mode menu on the recorder, and PCM from the REC Set - REC mode menu.You can record 'seperately' to the two channels with your mono mics by using a mono - stereo splitter and place the mics close to each interviewee. There will be some overlaps in the recording, but should be more separation than usual. Something like a SonyECM MS907 stereo mic should also give some left-right separation.Hope that helps. Quote Link to comment Share on other sites More sharing options...
CarolinePiercy Posted July 4, 2007 Author Report Share Posted July 4, 2007 Borat said: You can record in PCM on 'normal' MDs with your NH700. Just make sure you choose Hi-MD mode from the Option - Disc Mode menu on the recorder, and PCM from the REC Set - REC mode menu.You can record 'seperately' to the two channels with your mono mics by using a mono - stereo splitter and place the mics close to each interviewee. There will be some overlaps in the recording, but should be more separation than usual. Something like a SonyECM MS907 stereo mic should also give some left-right separation.Hope that helps. Thank you very much - yes it really helpsCaroline Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 4, 2007 Report Share Posted July 4, 2007 Depending on how long the interviews are, you may need to use Hi-SP, which should be superb quality for voice recordings.Standard MiniDiscs will only hold about 28min of PCM, versus 2h 20min of Hi-SP. Quote Link to comment Share on other sites More sharing options...
