timknaggs Posted July 16, 2007 Report Share Posted July 16, 2007 Hi how is everyone, I hope anyone can help, I have a sharp md mt170. I am recording podcasts for my website. The recording on the mini disc sounds fine when i listen to it on my headphones. When i plug a lead from the headphone to the line in, of the computer the sounds is so quiet. Does anyone know why or what i could do to sort this out. When my father transfered his old tapes to cd he used the same line with his personal stereo and it worked fine.Any help you could give me would be very much appreciated.ThanksTim Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted July 16, 2007 Report Share Posted July 16, 2007 Find the volume control utility on your computer. It's probably in the Entertainment or Systems Tools section under the Programs - Accessories menu if it's a Windows PC. You can control the line in level under volume control.Also make sure the volume on your Sharp MD is turned up to maximum - this gives 'line level' output on the unit. Hope that helps Quote Link to comment Share on other sites More sharing options...
timknaggs Posted July 16, 2007 Author Report Share Posted July 16, 2007 Hi thanks for your help i did that, didn't make any difference but set to high. Borat said: Find the volume control utility on your computer. It's probably in the Entertainment or Systems Tools section under the Programs - Accessories menu if it's a Windows PC. You can control the line in level under volume control.Also make sure the volume on your Sharp MD is turned up to maximum - this gives 'line level' output on the unit. Hope that helps Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted July 16, 2007 Report Share Posted July 16, 2007 Perhaps a setting in Sounds and Audio Devices in the Control Panel needs changing? Other than that, an audio utility like the excellent (and free) Audacity will help to boost the volume of your sound files once you have imported them to Wav or MP3 etc. Quote Link to comment Share on other sites More sharing options...
