Sonic Stage Installation Error
metronome
After installing SonicStage 4.3 (full version) then reboot I get the following error message "The proceedure entry point omgutil9 could not be located in the dynamic link library OMGUtils.dll"
I'm using XP SP2, virus free.
When I go to open the program, I get "Cannot find OpenMg Secure Module".
Suggestions?
It sounds like something didn't get into the right place. Maybe it was blocked during installation.
Try uninstalling it with Add/Remove Programs and installing again. If you use the Sony online installer make sure your antivirus and firewall are turned off. Or use the full 3.4 installer from Downloads--it's a good stable version.
If that still doesn't work look at this link:
http://forums.minidisc.org/index.php?showtopic=8071
to clear all the SonicStage junk out of the registry before trying again.
(Note: If you have a Sony computer, don't delete all the Sony software registry items, just SonicStage and OMG.)
