kate.carr Posted July 18, 2007 Report Share Posted July 18, 2007 hi,i have searched forums and haven't found anything on this. so hopefully am not doubling up.went to transfer files to my minidisc last night to find neither sonicstage of simple burner would register the disc inside the MD.I have a MZ-NHF-700 and am using an earlier version of sonicstage (3.1 i think). i am running windows XP profressional 2002.the error message for simple burner tells me the disc in being used by another program which is impossible.the error message in sonicstage says the disc was not initialized by sonicstage. when i re-initialize it continues to say exactly the same thing.the minidisc appears fine in device manager.any suggestions?thanks.kate Quote Link to comment Share on other sites More sharing options...
A440 Posted July 18, 2007 Report Share Posted July 18, 2007 Do you have another disc you can try? It's possible it's just a bad disc. Does the unit read the disc if it's not connected to SonicStage? If the disc is blank or unreadable, or you don't care what's on it, you could also try Erase All or Format under the Edit menu on the MZ-NH700.It wouldn't hurt to update SonicStage to 3.4 at least (there's a full installer in Downloads). If I remember correctly, 3.2 finally allowed you to do more than one upload of a recording from the disc, and that's an important upgrade from 3.1 . Quote Link to comment Share on other sites More sharing options...
kate.carr Posted July 18, 2007 Author Report Share Posted July 18, 2007 i've tried many discs and it always says the same thing. i'm going to upgrade to 4.0 i think, tomorrow. Quote Link to comment Share on other sites More sharing options...
RoGeR Posted July 18, 2007 Report Share Posted July 18, 2007 Just go straight for the newest 4.3! Quote Link to comment Share on other sites More sharing options...
A440 Posted July 19, 2007 Report Share Posted July 19, 2007 Make sure the unit is connected directly to the computer, not through a USB hub. And if you have a lot of other USB connections going, even from another port, unplug them while you try SonicStage. Are you saying that the unit can read the discs and SonicStage can't? Or that the discs are always unreadable? Quote Link to comment Share on other sites More sharing options...
