philthebass2 Posted August 1, 2007 Report Share Posted August 1, 2007 Hi, my first post so apologies for not knowing the right format yet.As a dedicated minidiscx user I upgraded recently to Sonicstage CP 4.3 and suddenly all my saved CDs (saved in wav format to keep quality) don't play in correct track order on the PC. If you play track 1, when it gets to the end it'll jump to track 4! It seem to jump three tracks at a time. Shuffle play is not on. Reinstalled SS3.0 and the library plays fine again. Then ripped a CD to wav under 4.3 and the fault is still there. If I convert to an MP3 format it plays sequentially as you'd expect!Anyone come across this please? All advice welcome. Quote Link to comment Share on other sites More sharing options...
A440 Posted August 1, 2007 Report Share Posted August 1, 2007 The only reason for 4.3 is Vista compatibility. If it's not working for you, I don't see any reason to bother with it.But you should definitely move to 3.4 or above because of many bugfixes and lifted restrictions compared to 3.0. There's a full 4.0 installer in Downloads. Quote Link to comment Share on other sites More sharing options...
RoGeR Posted August 1, 2007 Report Share Posted August 1, 2007 When you're in album view in My Library, did you make sure you clicked the Track Number column. Quote Link to comment Share on other sites More sharing options...
philthebass2 Posted August 2, 2007 Author Report Share Posted August 2, 2007 Thanks A440 and RoGeR. Interestingly SS4.0 still has this feature! I've tried reordering the tracks on an album (great idea), yet the increment it jumps in a wav saved album still appears to be three tracks. Can anyone replicate this on their PCs? Quote Link to comment Share on other sites More sharing options...
philthebass2 Posted August 7, 2007 Author Report Share Posted August 7, 2007 Hey dudes, 84 people have read this. Help me out here... if you save a CD as wav under SonicStage 4.0 or later on your PC, then replay it via SonicStage, does it jump from track 1 to track 4? Can't believe 80 minidisc friends haven't wanted to help yet, now you can :-) Quote Link to comment Share on other sites More sharing options...
