biber Posted August 1, 2007 Report Share Posted August 1, 2007 Forgive me for posting this again as a new topic, but I'm a little leery of downloading an updated version of SonicStage (I currently have 3.0, which came with my HiMD, but everyone seems to agree that it's fairly useless). Should I uninstall the old version first? Will downloading a new one do anything to previously transferred sound files, and/or risk mucking up the file transferring/CD burning functions on my computer? Quote Link to comment Share on other sites More sharing options...
raintheory Posted August 1, 2007 Report Share Posted August 1, 2007 (edited) First remove DRM from your files by following the instructions in this thread: http://forums.minidisc.org/index.php?showtopic=16088Then uninstall and reinstall either 3.4, or 4.2 (4.3 if you have Vista).If you don't remove the DRM on your files first, you run the risk of not being able to play them or transfer them when you uninstall/reinstall. Removing DRM prevents any problems.Download Links3.4 : http://forums.minidisc.org/index.php?showtopic=118894.2 : http://forums.minidisc.org/index.php?showtopic=17769 Edited August 1, 2007 by raintheory Quote Link to comment Share on other sites More sharing options...
biber Posted August 2, 2007 Author Report Share Posted August 2, 2007 Actually, I've already used SoundForge to edit and save (as wav files) the sound I transferred from my HiMD, so I'm wondering if the SonicStage DRM issue applies. I guess before I do anything else, I could test the play/transfer thing by putting the sound onto a thumbstick and seeing if I can open and play it on another computer.Good to know that once I've established this, I should uninstall the old version of SonicStage before downloading the new. Thanks! raintheory said: First remove DRM from your files by following the instructions in this thread: http://forums.minidisc.org/index.php?showtopic=16088Then uninstall and reinstall either 3.4, or 4.2 (4.3 if you have Vista).If you don't remove the DRM on your files first, you run the risk of not being able to play them or transfer them when you uninstall/reinstall. Removing DRM prevents any problems.Download Links3.4 : http://forums.minidisc.org/index.php?showtopic=118894.2 : http://forums.minidisc.org/index.php?showtopic=17769 Quote Link to comment Share on other sites More sharing options...
raintheory Posted August 2, 2007 Report Share Posted August 2, 2007 Yeah if they're WAV, you're fine. Quote Link to comment Share on other sites More sharing options...
A440 Posted August 2, 2007 Report Share Posted August 2, 2007 I was just idly wondering if the File Conversion Tool existed in 3.0, or if it was added later. I have always backed up My Library (with the Backup Tool, not just copying it) when upgrading SonicStage. But I think I only had to restore from that backup once, and that was because I tried to change the location of My Library from the default. Now whenever I install SS I just leave the defaults. The crucial reason to upgrade from 3.0 is that in (I think) version 3.2 and above, you no longer only had one chance to upload your recordings. Before that--I think even with 3.0--you got one chance to upload, and if you tried to do it again for any reason, SonicStage ERASED THE ORIGINAL FROM THE DISC. Nasty. So please upgrade to at least 3.4 as soon as you can. Quote Link to comment Share on other sites More sharing options...
biber Posted August 8, 2007 Author Report Share Posted August 8, 2007 A440 said: I was just idly wondering if the File Conversion Tool existed in 3.0, or if it was added later. I have always backed up My Library (with the Backup Tool, not just copying it) when upgrading SonicStage. But I think I only had to restore from that backup once, and that was because I tried to change the location of My Library from the default. Now whenever I install SS I just leave the defaults. The crucial reason to upgrade from 3.0 is that in (I think) version 3.2 and above, you no longer only had one chance to upload your recordings. Before that--I think even with 3.0--you got one chance to upload, and if you tried to do it again for any reason, SonicStage ERASED THE ORIGINAL FROM THE DISC. Nasty. So please upgrade to at least 3.4 as soon as you can.O.K., so I have downloaded SonicStage 4.0, but I am now chicken to try moving anything from my minidisk to my computer because I'm afraid that I'll lose stuff from the minidisk, which I absolutely can't afford to do (I'm a reporter, and this is sound I collected for a story). With 4.0, has the danger of that gone away? What can I do to make sure my audio doesn't get vaporized? Quote Link to comment Share on other sites More sharing options...
raintheory Posted August 8, 2007 Report Share Posted August 8, 2007 biber said: O.K., so I have downloaded SonicStage 4.0, but I am now chicken to try moving anything from my minidisk to my computer because I'm afraid that I'll lose stuff from the minidisk, which I absolutely can't afford to do (I'm a reporter, and this is sound I collected for a story). With 4.0, has the danger of that gone away? What can I do to make sure my audio doesn't get vaporized?That limitation was lifted with 3.4 i believe, and hasn't been an issue since. If you want to be extra careful you could always playback the disc using SonicStage and record the audio in realtime using Audacity or some other audio editing software prior to actually uploading.. Quote Link to comment Share on other sites More sharing options...
