hober Posted August 3, 2007 Report Share Posted August 3, 2007 I have a mz-nf810 about 4 years old.It hadn't been used lately. I tried turning it on and it didn't work so I figured battery was drained. I plugged it in and battery wouldn't start to charge. (It plays fine being plugged into wall.) So I thought the battery was bad. Got a new battery and it won't start charging either. I borrowed a friend's battery which was definitely working in her minidisc - but mine still wouldn't play. ANy ideas on what to do now?Thanks. Quote Link to comment Share on other sites More sharing options...
A440 Posted August 23, 2007 Report Share Posted August 23, 2007 Try cleaning the battery terminals in the unit with a Q-tip and a little bit of rubbing alcohol, in case the problem is something as simple as them not making contact. Quote Link to comment Share on other sites More sharing options...
