NWA3000-transfer files to another PC
jof
Hi
I have searched all forums for advice - but does not seem to be listed so sorry if I have missed it.
I want to transfer EVERYTHING on my NWA3000 to a 'clean' (ie no CONNECT PLAYER / SS) pc. Is there anything I should be concerned about?
Can I merely 'plug n play' the device - ie navigate to the device through windows explorer? Will i need to install driver files first?
I am a little wary about doing this without advice as I have (like others) experienced too much frustration with the software to date (the unit itself is awesome !!!) to be confident I wont experience problems.
All advice very much appreciated :)
6 answers to this question
If a computer has windows xp then it will automatically install your A3000 as removable drive (There is no need for extra driver`s).
In Windows Explorer (My Computer ) you will see A3000 as "Removable Drive ".You can easily drag or drop anything you like from your Computer .
Guest Stuge
it's pentium 2
64 mb ram
is there any solution other than upgrading my pc?
You can use A3000 as removable drive by installing Drivers for it (Which is present with SOnicStage or Connect Cd)[in Win98]
But don`t even dare to install Connect or SonicStage with 64mb ram(Pentium 2) .Idea solution is upgrade your PC .
