whatswisdom Posted August 15, 2007 Report Share Posted August 15, 2007 (edited) (Still a newbie.) I'm trying to transfer my old cassette tapes to MD. Last night I hooked everything up: Line-out from Sanyo RD-5008 Tape Deck (2 RCA plugs) >>> Line-in to Sony STR-DE325 Tuner/Amp (2 RCA plugs) >>> Line-out from Sony amp (2 RCA plugs) >>> Line-in to Sony MZ-RH1 HI-MD (single plug). Result: No signal coming in to MD.(When I switch the function button on the front of the amp from Tape/MD to FM radio, with the same connections as above, the radio signal comes through to MD no problem.)Any help appreciated. Thanks. Edited August 15, 2007 by whatswisdom Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted August 15, 2007 Report Share Posted August 15, 2007 Personally, I would bypass the tuner all together. Line out of tape deck straight to line in on MD unit. That is what I do. Quote Link to comment Share on other sites More sharing options...
bobt Posted August 15, 2007 Report Share Posted August 15, 2007 KrazyIvan said: Personally, I would bypass the tuner all together. Line out of tape deck straight to line in on MD unit. That is what I do.agreed, the fewrr obstructions in the path the beter the recording,Good luck,Bob Quote Link to comment Share on other sites More sharing options...
whatswisdom Posted August 15, 2007 Author Report Share Posted August 15, 2007 bobt said: agreed, the fewrr obstructions in the path the beter the recording,Good luck,BobThanks guys. I'll try it when I get home tonight. I didn't think the deck alone would have enough power to provide a strong audio signal. Quote Link to comment Share on other sites More sharing options...
