estate Posted September 3, 2007 Report Share Posted September 3, 2007 I would appreciate very much if someone would explain to me which are the steps to follow to enter in service mode in a mz-rh1 unit.Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 3, 2007 Report Share Posted September 3, 2007 The process is explained elsewhere in the forums, but I'd rather advice that you don't. The volume limit on European RH1's is not that horrible as on second generation units. No other limits are imposed. Quote Link to comment Share on other sites More sharing options...
estate Posted September 4, 2007 Author Report Share Posted September 4, 2007 Avrin said: The process is explained elsewhere in the forums, but I'd rather advice that you don't. The volume limit on European RH1's is not that horrible as on second generation units. No other limits are imposed.Thanks for your advice Avrin. Quote Link to comment Share on other sites More sharing options...
