littlefox Posted September 11, 2007 Report Share Posted September 11, 2007 I've been trying versions of SonicStage from 4.0 all the way to 4.3 on my Vista Home Premium system and it's consistently crashing at the same spot every time during startup; it loads fine until it reaches the "Loading UI components" bit and then crashes and dies, leaving my with a cryptic Windows error message box as follows: Quote Problem signature: Problem Event Name: APPCRASH Application Name: Omgjbox.exe Application Version: 4.2.2.11020 Application Timestamp: 45497363 Fault Module Name: Items.dll Fault Module Version: 3.9.2.11020 Fault Module Timestamp: 45496e9a Exception Code: c0000005 Exception Offset: 00013247 OS Version: 6.0.6000.2.0.0.768.3 Locale ID: 1033 Additional Information 1: f11a Additional Information 2: 4386d971a23fdb563f852c93c431c5a3 Additional Information 3: bc1e Additional Information 4: 525636ba7ae93a1cc4a10163243779f2Any help at all will be most welcome. Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 11, 2007 Report Share Posted September 11, 2007 Disable any Windows themes. Quote Link to comment Share on other sites More sharing options...
littlefox Posted September 11, 2007 Author Report Share Posted September 11, 2007 Avrin said: Disable any Windows themes.Tried that by switching to classic Windows. Didn't help. Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 11, 2007 Report Share Posted September 11, 2007 Which SS version are you currently using? Only SS43 works with Vista. Quote Link to comment Share on other sites More sharing options...
littlefox Posted September 12, 2007 Author Report Share Posted September 12, 2007 Avrin said: Which SS version are you currently using? Only SS43 works with Vista.I tried 4.3 first. I tried the earlier versions to see if the problem was specific to 4.3, which it wasn't. Quote Link to comment Share on other sites More sharing options...
bobt Posted September 12, 2007 Report Share Posted September 12, 2007 I had some crash issues with 4.3 in my Vista system, ends up my problem was one of my memory chips wasn't firmly seated, caused no end of problems. Try reseating your memory and see what happensBob Quote Link to comment Share on other sites More sharing options...
littlefox Posted September 12, 2007 Author Report Share Posted September 12, 2007 I tried reseating the memory, but it didn't work either.Anyway, a miracle: I managed to get it to work by fiddling with the permissions for Omgjbox.exe and items.dll. I switched on the permissions to allow users to modify and write to the two files.Others may wish to try this. Quote Link to comment Share on other sites More sharing options...
crowe80 Posted October 7, 2007 Report Share Posted October 7, 2007 littlefox said: how did you switch on the permissions to allow users to modify and write to the two files ?? Quote Link to comment Share on other sites More sharing options...
Guest bugnot Posted October 27, 2008 Report Share Posted October 27, 2008 Its far easier... RUn it as administrator or shut down the UserAccountControl(UAC).Worked fine... Quote Link to comment Share on other sites More sharing options...
