Tokend Posted September 18, 2007 Report Share Posted September 18, 2007 PROBLEM SOLVED: (In posting the following problem, I stumbled upon my own solution, so I no longer need help on this. I post the origninal problem and solution here, though, in case someone else can benefit.) PROBLEM:I'm hoping someone can help. Recently, I installed an external hard drive (Seagate FreeAgent), via Firewire 400. The drive comes up as drive N:, and all is well. However, upon starting SonicStage 4.0, I find that SS can no longer see my MZ-RH1. I think the RH1 used to be drive N. What's worse is that the computer, itself, can no longer see the RH1. When I connect the USB cable to the drive, WinXP boops and the RH1 springs to life. Device Manager shows "SONY HI-MD WALKMAN USB Device" as enabled and working properly. However, no drive letter has been assigned, and I can't see the RH1 in Explorer. I have rebooted and cold started. Still, no MD. SOLUTION: The problem was that Windows was using the same drive letter for two purposes: for the RH1, and for a shared network drive. I could see the network drive in Explorer under the drive letter, but not the RH1. To fix this, go into Control Panel > Administrative Tools > Computer Management. Select Storage > Disk Management. Find the confused drive letter assignment in the display of Disks. In my case, the RH1 showed up as Disk 6, drive letter O: (same as the network drive), and "965 MB Healthy." Well, inasmuch as the network drive is much bigger than 965 MB, and a MD is just about 965 MB, I figured this must be the problem. Sure enough, reassigning the drive letter of Disk 6 to an unused letter (L:) did the trick. Now I can see both the RH1 and the network drive in Explorer, and SS sees the RH1. I hope this helps someone Quote Link to comment Share on other sites More sharing options...
Avrin Posted September 19, 2007 Report Share Posted September 19, 2007 The solution is absolutely correct and professional! Quote Link to comment Share on other sites More sharing options...
