New to MD/Field Recording Question
mahler007
I'm looking around at recording options for some field recordings I'm going to make in Papua new guinea. I think MD is about my best bet, since Flash based units would fill up too quickly. I want to do some recordings of birds/ambient jungle sounds for future use in documentaries and some personal recordings of people/local music.
I want to spend about $100 on a recorder. So I was thinking of the MZ-NH700 (Uses AA Batteries); what's a good price to pay for this used?
Do I need a pre-amp for this?
I might as well throw this in too, a decent microphone that can be "hidden" (binaurual?). And another mic for 'up-close' recordings.
any help would be very appreciated
Edited by mahler
$100 is too low a budget. NH700 would do the job but it was about $180 new and is disappearing. They still show up on Ebay, but not for under $100.
A good basic concealable omni mic is the Sound Professionals BMC-2, the size of pencil erasers.
http://www.soundprofessionals.com/cgi-bin/gold/item/SP-BMC-2
But the better the mic, the better the result.
Up close, people here have recommended the Audio-Technica AT822 and the Nady CM-25.
For good quality with quiet ambient sounds, your birds and jungle noises, you're probably going to need a preamp, unfortunately. Minidisc preamps are good for their size, but they add hiss if they have to do a lot of work.
Remember, a Hi-MD disc is only 1 GB. That's 90 minutes of PCM and just under 8 hours of Hi-SP. I don't know what quality you need for your documentaries.
You should look at this site:
http://www.quietamerican.org/
