Dagger_pca Posted November 9, 2007 Report Share Posted November 9, 2007 hello everybody,i've got an sharp md recorder and some days ago i wanted to use it after a pause about a month,i've just turned it on (the md was already inside), but after a standard check, the recorder said,it can't read the toc. i thought, maybe the md was bad, so i've used another one and another one,the problem stays.do i have a chance to get it running by my own, please tell me, what can be the metter for this problem?thank you for attention Quote Link to comment Share on other sites More sharing options...
bobt Posted November 9, 2007 Report Share Posted November 9, 2007 hello everybody,i've got an sharp md recorder and some days ago i wanted to use it after a pause about a month,i've just turned it on (the md was already inside), but after a standard check, the recorder said,it can't read the toc. i thought, maybe the md was bad, so i've used another one and another one,the problem stays.do i have a chance to get it running by my own, please tell me, what can be the metter for this problem?thank you for attentionTry taking the battery out for a few minutes, and then see what happens. It could also be the head track needs lubrication, can you hear the head moving or the disc spinning. Info on the model of unit would be nice, as well, are you using the right disc??Good luckBob Quote Link to comment Share on other sites More sharing options...
Superbaldguy Posted November 10, 2007 Report Share Posted November 10, 2007 It may not make it any worse by giving the unit a bit of a whack, sometimes the thread screw is a bit stiff after not being used for awhile. Quote Link to comment Share on other sites More sharing options...
Dagger_pca Posted November 10, 2007 Author Report Share Posted November 10, 2007 hello, thank you for support at the beginn, it works normally, just after a check, when TOC reading were running it said "can't read a",but everything others worked, i heared everything moving, head and so on...now, few minutes ago, i followed advice to hit this recorder a little :/ now works nothing,now recordes says: "Err-MD80" and nothing moves inside. i've opened it and i could seethe part with the laser head doesn't move, it stopped away from the right place, where it was everytimei've opened it :/ so i helped with my finger to the right place, but the problem stay :/ hm well... thank you guys for replys Quote Link to comment Share on other sites More sharing options...
