Sonicstage install not working
ammar_sidhu
I'm having a really strange problem with sonicstage all of a sudden. First off, I have a running copy of sonicstage on my old computer, but I'm switching comps, so i need to install it on my new computer.
When I install 4.3 from the website, the installation seems to go ok, but when I reboot it hasn't installed sonicstage. All the files are missing and the sony folder is empty. I then tried to install the old 3.4 version, and i get a wierd error
"an error (5009:0x8002802b) has occurred
please make sure you have finished any previous setup and closed other applications"
I'm at a loss of what to do next. Thanks for your help.
Make sure you have full Administrator rights when installing SonicStage. And don't install version 4.3, unless you have Vista. Under Windows 2000/XP just install version 4.2, which is much more stable.
Also, the installation of SonicStage will not work if your computer is connected to a domain, it only works on stand-alone computers.
Edited by Avrin
