travis Posted November 21, 2007 Report Share Posted November 21, 2007 I'm looking to sell my MZ-RH10 minidisc but the battery doesn not work. I bought this battery on ebay from china and i dont think it ever quite worked correctly or held a charge. Is that the only place to get a battery? And when I put the device on the charger is there anything i have to press to start the charge or should it start charging automatically? thanks Quote Link to comment Share on other sites More sharing options...
Avrin Posted November 21, 2007 Report Share Posted November 21, 2007 There are known fake batteries for the RH10 on eBay. They do not hold charge sufficiently, and may swell inside the unit, damaging it forever. The best battery for the RH[9]10, and for other units which take a gumstick battery, is actually the GP gumstick, which can be found very easily.And yes, you have to press the STOP/CHG button to start charging the battery. Quote Link to comment Share on other sites More sharing options...
