fabinc Posted November 28, 2007 Report Share Posted November 28, 2007 (edited) how do I reset a mz-n505 back to it's default settings? I thought I found some instructions but they didn't work. I tried to make some adjustments to mine since it would no longer record even on new disk. I was about ready to trash it, but I figured I would at least try this 1st. It may be a matter of the heads being dirty too, so if someone knows what you use to clean the heads let me know. Thanks for anyhelp offered. Edited December 3, 2007 by fabinc Quote Link to comment Share on other sites More sharing options...
fabinc Posted December 3, 2007 Author Report Share Posted December 3, 2007 how do I reset a mz-n505 back to it's default settings? I thought I found some instructions but they didn't work. I tried to make some adjustments to mine since it would no longer record even on new disk. I was about ready to trash it, but I figured I would at least try this 1st. It may be a matter of the heads being dirty too, so if someone knows what you use to clean the heads let me know. Thanks for anyhelp offered. i found the answer finally here - http://forums.minidisc.org/index.php?showtopic=7903 . Know I just need to know how to clean the heads.i found the answer finally here - http://forums.minidisc.org/index.php?showtopic=7903 . Now I just need to know how to clean the heads. Quote Link to comment Share on other sites More sharing options...
