quadnut Posted December 7, 2007 Report Share Posted December 7, 2007 I've been uploading my MDs to my XP computer via SS 4.2 through an RH1 recorder. Every time it finishes uploading an album it asks if I want to register with Gracenote for album info (I've been declining each time). Does Gracenote cause any restrictions or any negative things I may not want? Just trying to be careful about uploading things to my computer as it can be very hard to get rid of them later. Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
bobt Posted December 7, 2007 Report Share Posted December 7, 2007 I've been uploading my MDs to my XP computer via SS 4.2 through an RH1 recorder. Every time it finishes uploading an album it asks if I want to register with Gracenote for album info (I've been declining each time). Does Gracenote cause any restrictions or any negative things I may not want? Just trying to be careful about uploading things to my computer as it can be very hard to get rid of them later. Thanks for any advice.AFAIK Gracenote isn't any harm, it just builds a databasa of album info, I wouldn't worry about it, just contributing to the cause as it were.JMHOBob Quote Link to comment Share on other sites More sharing options...
quadnut Posted December 7, 2007 Author Report Share Posted December 7, 2007 AFAIK Gracenote isn't any harm, it just builds a databasa of album info, I wouldn't worry about it, just contributing to the cause as it were.JMHOBobOk, thanks Bob. Quote Link to comment Share on other sites More sharing options...
Avrin Posted December 7, 2007 Report Share Posted December 7, 2007 Actually, you already have Gracenote (CDDB) files installed on your computer (these are installed during the installation of SonicStage). So, register, and start using the service - it saves a lot of time. Quote Link to comment Share on other sites More sharing options...
quadnut Posted December 7, 2007 Author Report Share Posted December 7, 2007 Actually, you already have Gracenote (CDDB) files installed on your computer (these are installed during the installation of SonicStage). So, register, and start using the service - it saves a lot of time.Good to know. So glad I have you guys as a resource! Quote Link to comment Share on other sites More sharing options...
