agafly Posted January 6, 2008 Report Share Posted January 6, 2008 Hi Sorry if this is not in the right place for this question but I was under the impression Sonicstage 4.3 had been decluttered of licence problems DRM etc.I play in a band which do original material which have in the past recorded on to my RH1 and imported in to SS with no problems. My hard drive died so rebuilt everthing and redownloaded SSI then copied the original files form a back up to the new SS directory. Now they will not play at all as it cannot obtain the license info for the files. This is rubbish as it is my music! Dose any one know how I can get round this stupid error? Sorry if this has been covered else where But any help would sure be appreciated!Happy new year by the way! Quote Link to comment Share on other sites More sharing options...
raintheory Posted January 6, 2008 Report Share Posted January 6, 2008 Can't help you with recovering the stuff, but see the link in my signature regarding stripping DRM to avoid this problem with future recordings. Quote Link to comment Share on other sites More sharing options...
agafly Posted January 7, 2008 Author Report Share Posted January 7, 2008 Thanks On further investigation this dose appear to be a problem from not importing from a proper backup also incompatibility with older versions od SS (which I had).Sadly Sony it it's shortsightedness has not allowed for someone like me which suffers a simple hard drive failure.Just hope I can find the original discs! Quote Link to comment Share on other sites More sharing options...
eshmx Posted January 14, 2008 Report Share Posted January 14, 2008 Hello everyone, I bought a MD about 3 years ago, I do not remember the modelo, then las year bought a newone but Idid not install the 1.5 sonic stage instead, I installed the 4.3 version and at the begining it was working fine, however these hollydays I bought nore MDs and then the problem began, when I tried to record the songs there is a message that says "can not import the selected tracks" and then It gives me some reasons but the strange is that I tranfered those songs before with the same software, computer and MD, I try to reconvert the files in mp3 however the problem presists, can anyone help me with this problem?Thanks Quote Link to comment Share on other sites More sharing options...
raintheory Posted January 14, 2008 Report Share Posted January 14, 2008 (edited) Hi there... I've run into problems (as have others) importing using 4.3 on operating systems other than Vista.If you're not using Vista, try 4.2: http://forums.minidisc.org/index.php?showtopic=17769 Edited January 14, 2008 by raintheory Quote Link to comment Share on other sites More sharing options...
pitdroidtech Posted January 14, 2008 Report Share Posted January 14, 2008 eshmx1977 said: Hello everyone, I bought a MD about 3 years ago, I do not remember the modelo, then las year bought a newone but Idid not install the 1.5 sonic stage instead, I installed the 4.3 version and at the begining it was working fine, however these hollydays I bought nore MDs and then the problem began, when I tried to record the songs there is a message that says "can not import the selected tracks" and then It gives me some reasons but the strange is that I tranfered those songs before with the same software, computer and MD, I try to reconvert the files in mp3 however the problem presists, can anyone help me with this problem?Thanksraintheory's suggestion is sound, but if you have no luck with 4.2, repost with the possible reasons given for the message you get. Even though software error messages often seem obscure, to those with more experience they often pin point exactly what is wrong. Best of Luck Quote Link to comment Share on other sites More sharing options...
