mnmleung Posted March 3, 2008 Report Share Posted March 3, 2008 Hi, I have a PC which has an SS 4.2 library with 4000+ tracks. Today all of a sudden, the transfer from MD stops working: usually it would ask me if I really wanted to transfer etc but now it doesn't even ask.I have a laptop also with SS 4.2, and the same MD player, same HiMD transfers OK to the laptop. So I am guessing it is the software on my PC, not the MD or MD player, or the cable.Is there an upper limit for the size of my music library? Or did I "knock" some settings off ? If so, is there some way to "reset" this so that I can again transfer HiMD to my PC? Thank you very much. From Ming Quote Link to comment Share on other sites More sharing options...
Avrin Posted March 3, 2008 Report Share Posted March 3, 2008 I've seen transfers stopping unexpectedly. Rebooting the computer usually helps. Quote Link to comment Share on other sites More sharing options...
mnmleung Posted March 4, 2008 Author Report Share Posted March 4, 2008 Avrin said: I've seen transfers stopping unexpectedly. Rebooting the computer usually helps.Thanks, Avrin, rebooting and unplugging my other USB cables helped and I can transfer again now. Thank you. Ming Quote Link to comment Share on other sites More sharing options...
