Uploading to a PC
larryweiner
Hi all ---
I'm beginning the process of transferring all my old mini discs to my computer (a PC) and was writing to ask for opinions on the best way to do it. I've got a number of Minidiscs recorders/players starting from my ancient MZ-1, MZ-R50, MZR-909, and a MDSJB930 deck. I have lots and lots of field recording I want to upload and would prefer to upload them using some sort of higher speed technique (USB-firewire etc), but haven't found noticed any way to do that. I'd also prefer NOT go through the line-out because generally the A/D converters are not particularly good and would prefer to go directly through my good sound card on my computer (m-Audio). I could youse the SPDIF or Toslink output on the MDS-JB930, but that is also in real time (not high speed). Any suggestions?
The newest recorder: The MZ-RH1 -will upload any older discs (assuming they werent created with SonicStage or OpenMG software... so any mic or line recoridngs, etc) faster than realtime via USB, and is the only recorder that will do so. If you're looking for a quick way, this is unfortunately your only option. It is unlikely that SONY will create any future MD recorders.
Edited by raintheory
You may also find the MZ-RH1 for sale as the MZ-M200, which is exactly the same thing plus a Sony DS70P microphone.
Although you obviously don't need the mic, it may be the only way you'll find the unit you need.
Also, I think you'll need a PC (not a Mac) to upload what are now called "legacy" formats. The RH1 comes with an installation disc for the uploading program SonicStage 4.2, which is a good version that runs on Windows XP. If you are running Vista you'll need to get SonicStage 4.3 from the Sony website. Otherwise, stick with 4.2--it's better for non-Vista systems.
Edited by A440
