crawf Posted March 19, 2008 Report Share Posted March 19, 2008 Hi Guys, Just a quick question...But when i'm adding music to my RH1, the new files seem to always go at the very bottom of the list. Which is a bit of a pain...Its easy to get them in alphabetical order in My Library, but it just doesnt want to seem to go in order on the actual MiniDisc. Initially, the songs i put in there are fine, its just when i come back later to add a few more songs, they are added to the bottom. Anyone had this problem?Also, it seems i can upload the same song twice, and it just adds another 'version' of that song to the end of the list. Shouldn't it detect its already on there, and offer to skip/overwrite that file?Anyway, would like to know if anyone else has found a solution to this!-Josh Quote Link to comment Share on other sites More sharing options...
crawf Posted March 24, 2008 Author Report Share Posted March 24, 2008 No one has had this problem?? Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted March 24, 2008 Report Share Posted March 24, 2008 Isn't that the way it's supposed to be, adding tracks to the end? You can always change the order on the disc once you've transferred. Quote Link to comment Share on other sites More sharing options...
crawf Posted March 26, 2008 Author Report Share Posted March 26, 2008 I guess so...But, for example, in iTunes, it would automatically sort the tracks alphabetically, which is much more organised i guess...I have noticed sonicstage has always done this, was simply wondering if it was meant to be that way Thanks, -Josh Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted March 26, 2008 Report Share Posted March 26, 2008 Sorry, it's just the way Sonicstage does things. You get used to it eventually. It's the the way with minidiscs anyway, though I think with the hard drive machines that used SS (I had the Vaio pocket and HD5), it may have been different, I can't quite remember. Quote Link to comment Share on other sites More sharing options...
crawf Posted March 26, 2008 Author Report Share Posted March 26, 2008 Yeah, its done it even since i remember, which is fine. Thanks anyway for clarifying that!-Josh Quote Link to comment Share on other sites More sharing options...
